Touched Up stock Valve covers
Old 07-07-2012, 12:01 AM
87DodgeD150's Avatar
Default Touched Up stock Valve covers
I got a little bored tonight and decided to paint my valve covers.
Tomorrow they will get a few coats of engine pain clear.
Old 07-07-2012, 11:47 AM
Heres how it looks all said and done.
Everything was cleared with high temp engine paint. The stripe is the same chevy engine orange. I'm not Chip Foose when it comes to painting but, I try to make this turd look good.
Old 07-07-2012, 01:32 PM
sjsingle1's Avatar
how is the truck coil bracket working? i had to lower mine cuz it hit EVERYTHING
Old 07-07-2012, 01:57 PM
works just fine. had no clearance issues
Old 07-07-2012, 02:02 PM
TBSOELS1's Avatar
looks pretty....
TBSOELS1's Avatar
how you like arkansas? what squadron you with?
Old 07-07-2012, 02:16 PM
Arkansas is ok im with 314 amxs
Old 07-07-2012, 02:23 PM
TBSOELS1's Avatar
got ya, just curious cause i had one of my good friends pcs down there about a month ago but hes SFS k9 so i guess you wouldnt know him
Old 07-07-2012, 02:42 PM
ahh ok. yeah wouldnt know.
Old 07-08-2012, 02:45 AM
sjsingle1's Avatar
Old 07-08-2012, 02:46 AM
sjsingle1's Avatar
Old 07-08-2012, 08:54 AM
My6speedZ's Avatar
Here is what I did with mine.
Finished product
I like the stripe, very original I don't think I have ever seen that done before.
Old 07-08-2012, 10:59 AM
Those look pretty good. What kind of primer did you use? red oxide high build?
Old 07-08-2012, 11:49 AM
My6speedZ's Avatar
That was actually red engine paint. I painted them red and hated it. I was just mocking up the trimmed coil bracket in that picture before I had finished stripping the valve cover.
I used the hi-temp engine primer and semi-gloss black. Then I dusted them with the Hi-temp clear to give them a little bit of that crinkle look.
Old 07-08-2012, 03:19 PM
Ahh ok I just used regular black paint and then used the high temp clear over them. I was going to do a red stripe to match the coil packs but the engine is chevy engine orange.
Old 07-08-2012, 09:17 PM
Kind of unrelated to engine prettyness, I'm going to do a little test with some heat shield between the valley cover and my intake manifold. I've seen old hotrodders coat the bottom of their intake manifolds with a ceramic material to deal with heat. Not sure if it will do anything but, it doesn't hurt to try.
