Cleaning and painting a roll cage
Old 09-07-2013, 10:34 PM
Italiankid77's Avatar
Default Cleaning and painting a roll cage
I just got the cage done on my car and I was wondering what you guys have used to clean and paint the cage.
Old 09-08-2013, 12:42 AM
hotrod 80's Avatar
Clean it with acetone . I like the hammertone paint from Lowes hardware . Finish has a nice look to it IMO .
Old 09-08-2013, 09:33 AM
thanks for the info
Old 09-08-2013, 05:30 PM
Blackpanther99's Avatar
I have always wondered the samething for cleaning a roll cage for a paint job.
Old 09-08-2013, 08:16 PM
scj
scj's Avatar
I've heard to clean it with a sock to get behind everything.
Old 09-09-2013, 09:35 AM
RENE'S RAGE's Avatar
Do you need to prime it before paint?
If so what primer to use.
Is the hammertone paint a spray or roll on?
Thanks
Old 09-09-2013, 04:37 PM
ctjohns's Avatar
I always use a self etching primer on my cages first, then paint
Old 09-10-2013, 10:39 AM
NnOoSsSs's Avatar
Id use high build personally and then sand er down and go on. But if you plan on using like just rattlecan which for a cage why not. Just normal can primer and rustoleum should work.
Old 09-10-2013, 10:45 AM
Old School Heavy
speedtigger's Avatar
How do you guys who are spray bombing get paint into the tight areas around the headliner and such?
Old 09-15-2013, 05:14 PM
BRUTL's Avatar
that's what I used to paint mine, mostly because all of my chassis/suspension is BMR hammertone. It turned out well.
Quick Reply: Cleaning and painting a roll cage
