Need adhesive for weather strip
I went to my local body shop to ask about the weather strip on my passenger door, it won't stay clipped. I can push it down but as soon as I use my window, it lifts back up off the door. Upon inspection, the fiberglass tabs the strip clips to are worn down. The body shop said the door would need to be replaced or I could find an epoxy to glue the strip to the fiberglass. He wasn't able to give me a specific epoxy, just said to ask paint shops around town. Does anyone know what I need to use to glue the metal clips on the weather strip to the fiberglass in the door?
I have the same problem on my 1999 TA. I don't think the door needs replaced, you just need to find a new window weather strip. Classic Industries has them for sell. As soon as I get some extra money I will be replacing mine.
I had this exact issue and what happens is the door actually gets worn where the clips slide into. I don't know if this is the correct way but it worked for me and I never had the issue again...
I popped up the strip all the way to the mirror but didn't remove it from the door. I slightly spread the clips open so they can grab onto the worn area of the door a little better, I then applied JB Weld 8265-S Cold Weld Compound onto each clip and popped the strip back down onto the door.
Do this at the end of the day so you have a good 10 hours or so before you drive the car, the longer the better so you don't disturb the glue. I waited around 10 hours before I drove my car and did not have any issues.
This is my 2 cents and hopefully it helps.
Also when you are pushing the strip back down onto the door make sure 100% that all of the clips are actually going into the slits in the door, sometimes they will slide away from it and obviously this wont help.
I didn't know that. Hopefully it will be cheaper to buy the weld compound than the new weatherstripping. Thanks.
Glad it worked! I'll have to do that in the spring.
