Fender moved
Old 05-29-2016, 01:31 PM
blackbirdls1's Avatar
Default Fender moved
The only thing that was recently done to my car that may have caused this was at a tire shop getting a nail taken out. It looks like the lower quarter panel shifted outwards, would this be a relatively easy fix? It looks like the metal piece that it is attached to under the car where there are 2 bolts located was bent. Makes me wonder if the shop was at fault, I will have no way of proving it though. Any advice appreciated.
Attached Thumbnails Fender moved-20160529_131020.jpg   Fender moved-20160529_131027.jpg   Fender moved-20160529_131049.jpg
Old 05-29-2016, 02:20 PM
98CayenneT/A's Avatar
bunch of clowns, ya that is what happens when hacks lift these cars by the pinch rails. It should suck back in when you bend the pinch rail back to straight, just be careful.
Is the plastic cracked that also bolts to the inside of the pinch rail?
Old 05-29-2016, 02:26 PM
Plastic? I don't see cracks anywhere, and I bet that's what did it. Looks hard as **** to bend.
Old 05-29-2016, 02:37 PM
I was looking for a picture on Google images and came across this thread. Give it a read. You will be able to get it right again, just go slow https://ls1tech.com/forums/paint-bod...-gap-pics.html
Old 05-31-2016, 07:56 AM
necrocannibal's Avatar
Yeah there is a bracket hanging down right behind the front tire that bolts the fender in. Just take a hammer and beat it back in or a big crescent wrench and bend it back in, takes about 2 minutes to fix.
Old 08-19-2018, 11:21 AM
white01ss's Avatar
Inexperienced techs tend to see that fender mount tab and think it's a jack point. Mine got mangled and bent back so many times that I had to cut it off and replace it with an L bracket. Such is life with an f-body.
Old 08-25-2018, 07:36 AM
That is basically how it happened. I was able to bend it and flush the fender. Looks normal.
Quick Reply: Fender moved
