Flat or satin black help
I got a new winter/DD car, a 93 Civic. The body is in an ok primer attempt; some of the original color shows through. I was thinking about spraying the car flat or satin black, so will one color cover better than the other?
Any tips on flat or satin black?
you could do this, use ppgs dbc system base coat black, then apply ppg`s flatnflex clear
its a clear that can be flattend down to achieve degress of gloss
or you could use hot rod flatz
this might make it more confusing being that there are a lot of options but here you go:
http://www.tcpglobal.com/kustomshop/ksflatz.aspx
