Wideband, Fuel Pressure, and Boost Gauges
Category: Accessories
Price: $1
Location (State): CA
Item Condition: Used
LS Engine?: Fits LS Engine
Prosport Wideband: Blue LED, 10-20 AFR. Bezel was painted satin black. Comes with the sensor, visor, wires, controller, mounting bracket, and two sensor bungs. SOLD
Wideband Air Fuel Ratio Gauge
Prosport Fuel Pressure Gauge: Halo version, 0-100psi. Comes with the sensor, visor, mounting cup and base, mounting bracket, and wires. I bondo'd a flat surface onto the buttom of the buttons so I could mount it remotely from the gauge, but it could be sanded back to round to mount onto the gauge. This is a really cool gauge, lots of features. SOLD
Prosport Gauges Halo series Fuel Pressure Gauge.
Speedhut Boost Pressure Gauge: 30inHg-20psi. Comes with sensor, wires, 1/8 NPT to 1/8" barb fitting, and lighting inverter for running the backlights, also allows you to dim the backlights using the factory dimming ****. Bezel was painted graphite to match the dash. There is some residual glue on the back of the gauge but it doesn't affect anything. SOLD
Speedhut Fuel Pressure Gauge: 0-100psi. Comes with sensor, wires, and lighting inverter for running the backlights, also allows you to dim the backlights using the factory dimming ****. Bezel was painted graphite to match the dash. SOLD
I also have an extra Speedhut lighting inverter and a y-connector for the intverters that I will give to the buyer of either Speedhut gauge.
Gauges - Speedhut
Please PM me with any questions.
The gauge shows error because the sensor isn't plugged in.
Picture taken under the light to see through the tint.
Still have the protective film on the lens.
