Need Wiring diagram for 08 Silverado
Like it says, I need a wiring diagram for an 08 Silverado (I believe) 4x4 with a 5.3l and 4l60e.
I specifically need the PCM outs, DBW and cruise.
If I need to buy a manual from GM, I will...
Thanks!
Thanks!
Awesome!!! Thanks!!!!!
I looked at Alldata and I couldn't find a listing for an 08 The only 08 listing I see is for a Jag...
Do you have more diagrams that I can get? That one I don't see some of the things I need and some of them I don't understand where they go. If I saw a diagram I would understand better.
07 was as close as i could get. may or may not be the same. compare to the other pinout should tell the tale though.
if you trim the edges and tape them together its real easy to look at.
Question though, I still don't see how the cruise control is done though. When I do this swap, I'd like to continue to have cruise. Any ideas? Or is there another computer for that?
Oh, do you have the same thing for an 04 Jeep Wrangler Rubicon, 4.0L and NV3550 (stick) trans? You'rs are much clearer and easier to read than the ones I have access to through AllData. Thanks!!!!
