E-water pump failure notifier?
Old 01-14-2009, 10:28 AM
Tricked-Out-Toy's Avatar
Default E-water pump failure notifier?
Im looking for a way to signal to me that the electric water pump has stopped pushing water.. how would you do it?
Old 01-14-2009, 07:32 PM
Moderator
jimmyblue's Avatar
If you can wait a minute or two, ECT ought to go
through the roof.
If the pump quits it ought to either be open circuit
(zero current) or locked-rotor (high current), both
can be sensed with a low value resistor (select so
normal pumping gives you maybe 500mV voltage
drop, ground side, and you'd have plenty of signal
for a pair of comparators to reliably detect under
or overcurrent.
Old 01-14-2009, 07:47 PM
through the roof.
or overcurrent.
Ya I dont want to wait till the temps spike, that could be deadly (overheating and locking up at highway speed) I like the over under Im just not sure our to build a something that can do that.. Id like to have it trip a light on the dash
Old 01-15-2009, 09:30 AM
Moderator
jimmyblue's Avatar
Here's a sketch, it's a basic window comparator
(you could find similar in the application notes
at www.national.com, LM339 comparator apps).
Lights the light if pump motor current sense is
too low or high, you have to select the sense
resistor so that it drops 500mV at normal.
Old 01-15-2009, 09:36 AM
SWEET! thanks man!
Old 01-15-2009, 01:00 PM
koolaid_kid's Avatar
Here are instructions on wiring the warning LEDs.
http://www.akmcables.com/2ledmez.jpg
