Where to mount wideband o2 sensor?
I put mine in the catback, this way it gets both banks instead of just one.
I had an issue with putting it in one side of the exhaust,
AFR reading would swing wildly.
under the passenger rear seat, there is grommet that you can run the sensor through and keep the controller in the car.
Cylinder 7 is the lean cylinder on a ls1. Cylinder 7 is on drivers side 1-3-5-7. I would put it on the drivers side just behind the narrowband o2. If its in the y then you read both banks and the drivers side bank could still be lean. If you have it in the lean bank, and you tune off it, then the passenger bank is either going to be the same or richer, just my 2 cents, Josh
with the stock PCM.
I believe what he means is to tune the one bank (that has a tendency to run lean) correctly, and run the other bank a bit fat. Rather than have the one bank run a bit lean and run the risk of burning a valve.
I can't disagree, as I would rather run a bit rich than a bit lean.
Anyways, regardless of which side you pick it's best to have the sensor as close to the collector as possible for more accurate results. If you're just doing it for tuning purposes and not a permanent install just use one of the existing o2 bungs. If it's a permanent install the put it a few inches behind the existing one.
Actually the instructions for the LC1 tell you to place the bung
3' from the end of the tail pipe unless you are running cats.
I could not get a steady reading from one side of the exhaust so placed the
sensor in a common point for both sides.
This probably was because of the cam.
The further away from the engine they are, the longer it take for the exhaust to get to it. Meaning if you were to have a lean spike, by the time the o2 sensor reads it you'll be at a different rpm. Possibly adding fuel to where it's not needed. All be it there is an extremely small difference in time, but there is a difference. Not to mention the further down the pipe you are the more chances of getting leaks from pipe connections.
Just because the reading wasn't steady doesn't mean that it wasn't right.
Use the supplied log works software and tweak the analog out settings to slow down the update. Get a bit more averaging this way and it helps.
This is definitely the case. At WOT your recorded AFR error on engines that come up decently will almost always be off by a cell anyway, but at least your cruise will be close. WOT tuning on VE means hand-editing cells and looking at logs to see the correlation between injector humps and dips; the wideband's reading will match the humps and dips but always lag pretty significantly.
on a 99 the cat runs right up there against the manifold on the driver's side.
i'd rather not pay an exhaust shop to remove the driver's side manifold to get a bung welded on (it would be cheaper to buy new high-flow cats and have the bung welded on the extra bit of pipe), but i need the bung on before the cats.
how much leaner could the driver's side bank be? it would be much easier in my case to weld it in on the passenger side, but i'm wary of taking any chances wiith a 150shot of nitrous.
what would you guys suggest?
here's some photos of the driver's side to show you what i'm working with.
would you recommend wideband o2 after cat on driver's side over wideband o2 before cat on passenger's side?
also.. its a huge pain in the ***, but i have checked plugs after spray and timing looks good, but i'm thinking its still rich.
all that rear o2 does is tell if the cat is going bad, right? i can tune that out. i've read where it is supposedly .5 leaner after the cat, is this a good rule of thumb?
Either side is fine. Still applies that a lot of the time the driver side is a little leaner.
On the nitrous just turn the timing down and get your fuel right. Just change the plug that is easiest to get to and when it gets close then check them all and make sure they're all pretty consistent and adjust accordingly. Keep an eye on your wideband just for a reference number to compare run to run.
