what sensors can i get rid of?
Im making a race car harness and want to ditch as much as poss. from the engine harness. Ill be running all external gauges so can i ditch off my temp., oil pressure, low oil sensor, etc? Or will this confuse the pcm on what to do?
SD still reads the O2 sensors, if your planning on running the car in open loop you can ditch them. If your in the gas hard the car goes into open loop either way, but i would leave the O2 sensors and closed loop cause it easier to get drivability back ( even if its just around the pits). This also could be cause i suck at tuning
