Synergy 2 step question
I can't seem to find the installation instructions for a 98 auto. Anyone have these handy or know where I can find them? Their website has been closed so thats out of the question. I found instructions that red93 had for a 99-02, but those are different.
Is Synergy still open ? Im looking to buy a 2 step and the Lingenfelter one stays on all the time if you have a 6speed. So everytime you push in the clutch it hits the 2 step as per other threads.
Location: sneaking in your back door as you leave!/cartersville ga
you can look up rick@synergy and it says banned.
he is a real nice guy. so dont let the "banned" come off as a bad term. it could have been something a simple as sponsorship dues or a simple disagreement.
LS1Tech Sponsor
Lingenfelter 2-step "always on"
Sorry to continue this topic that isn't really part of the original thread but...
Regarding the Lingenfelter 2-step being active on every shift on a manual transmission car, it depends on how you choose to activate it.
If you are using a clutch switch you can also use our MPH activated switch (STOV-001) to disable the 2-step once you are moving.
We also have several customers that allow the 2-step to trigger during the shifts to use it as an engine torque cut to help shifts and allow them to no lift shift.
LS1Tech Sponsor
Brake light switch
We have several automatic customers that have the 2-step wired to the brake light switch (with an inline switch so that it can be disabled under normal driving).
I assume the Synergy unit could also be wired to the brake light switch.
To the OP, mine is setup off the brake light switch, found under the dash above the brake pedal, and a window switch with WOT detect. Works like a charm. Brake pressed, foot to the floor = 2 step active. Off brake and it's go time.
Last edited by RZRSEDGE; 02-23-2009 at 01:48 PM. Reason: Brake light switch location
I believe the 6 speed guys use them so you're not tagging the rev limiter on the power shift. That and you didn't clarify you were talking solely about track use. Because of those 2 things I thought you were talking about driving on the street and being on the 2 step when you mashed the clutch. Still easily fixed with a momentary switch like used for a trans brake in conjunction with the clutch operation.
i thought you was selling it? i will try to send the instructions w/ my wife tommorrow to scan. i still havent fixed my scanner.
did it not come w/ instructions?
