random misfire code wtf? P0300
I had my car to the dealer today because of I've been setting random misfire codes. 150 misfires in #5 cyl. and 147 misfires in #8 cyl. They told me that my plugs and wires are fine and they don't have a clue how to fix it until someone from GM discusses it with them. Do you think that there is a problem with the coil packs. Any suggestions please.
Restricted User
Originally Posted by 2002SilverWS-6
no cam. stock internals.
I don't want to remove the random misfires from my tuning because my car is running like **** right now. You can definately hear when it is misfiring and also feel it. It is breaking up at 4700-5800 at wot in 3rd and 4th gear.
Well I went and changed my plugs to NGK tr55's and put on Taylor Thundervolt 10.4 wires and got rid of my random misfire code P0300 but now I am setting P0308 so does this mean that I only have a problem with #8 cylinder. My car is still breaking up at wot above 4700rpm in 3rd and 4th gear. I am going to swap the coil packs around to see if anything changes. Is there anything else I should do or look for. I don't think that I have a bent pushrod because the motor sounds quiet to me.
Had the same problems exactly the same problems. Found out it was bent PR and weak VS. A set of LS6 VS cured all my issues
http://www.ls1.com/forums/showthread...ighlight=valve
i overreved my engine one time went from a 3rd to 2nd on accident did this one time and thats it, car seems good sounds good and everything is monitoring out fine, is it possible that i may have a bent pushrod from this? it seems that its not as noticeable of a noise or anything and i jsut wanna make sure. like it said it was only once and i cought it REALLY fast...
Restricted User
Originally Posted by TILEMAN
Hey Silver, missing 3rd will get ya every time.
Originally Posted by 2001 Pewter WS6
Keep watching your avatar, you will eventually get the hang of it. Hey Tileman, think you might be able to hold a class and teach him where the gears are so this doesn't happen again???
