help car still dies...
just got done replacing the icm and i am having the same problem still. the car will just shut off after about 20 mins of running and will not start again for a few hours. when it dies its like i turned the key, it dosent hesitate at all it just stops. anyone have some suggestions??
pulled no codes, crankshaft position sensor? any ways to test this, because i am gettin tired of throwing parts at the car.... just would like to test it before i buy a new one if i can
i have heard that lt1's prior to 96 did not have a cps... also once in a while when i try to start my car back up after it dies the tach will do some wierd things like jump up to 2000 and then go back down... if that helps any
alright, i know it has to have something to do with going into closed loop. it is fine when its cold and when it warms up, even if its just from the sun it will die... i cant figure out what would be doing this.... what would shut off the engine in closed loop if it was going bad?
i can smell raw fuel when i try to start it again... but then again i have no cats so i could just smell whats still in the cylinder/ exhaust??
