idle issue...MS3
idle issue...MS3
when I first start the car, the car idles at 400rpms, then idles at 600 and then goes up to the set idle at 1000rpms...it takes about 6-7 seconds before it idles at 1k. The car drives and idles fine after that....it just does this everytime I start the car and its rather annoying because it sounds like its going to stall
I have HPT infront of me....how can I fix this?? Is it timing related or something else??
yah...thats what I was thinking too I just need someone to point out exactly which tables to add more airflow too as far as start up goes....everything else in the tune is perfect.
heres a quick idle clip of what its doing
sorry the video is all messed up, I think I bought a shitty tape to begin with
http://www.youtube.com/watch?v=9UctHwl7cjk
Note: This is on a hot start...on a cold start it idles normal. Also, usually it takes a few seconds longer to find idle then the video I posted.
yep, that is the exact same thing mine was doing. In the startup tables you need to add air at the temps that you are having the problem at. Since it starts fine when cold like mine you can leave those alone. I wish I had HP so I could explain to you what tables at what areas need changing.
however, this issue has been the same with the stock injectors and after so obviously the injector change isnt the issue.
