Deleting OBDII from 2001 SS, possible?
Hey guys. First off I want to say I know absolutely nothing about this, but I just wanted to ask this.
I'm tired of my car being a check engine monster, and I'm consistently throwing codes for emissions stuff that makes it a PITA to get inspected despite the fact that the car is meticulously cared for. It has LT Headers, and I'm thinking the O2's are what's causing the problem, but in general the whole thing is a pain in the ***.
Is it possible to just rip the entire PCM out of the car and get some type of standalone system to completely eliminate the emissions bullshit? Eventually I would also like to run a Racelogics traction unit also, and those things tend to not like OBDII cars.
Anyway, like I said I know absolutely nothing about it so I'm just wondering if it's possible. Thanks.
Woah woah calm down buddy Pick up a copy of HP tuners, hook it up, and turn off the check engine light for ANYTHING you want!!!! Dont waste your money on a stand alone computer when the GM computer will do everything you want it to
Also are you running the factory O2 sensor? If so that is a big part of your problem. With LT headers you need to use Bosch 13111 O2 sensors.
I just got done reading your two page thread. It's driving me nuts and I'm just ready to rip those bitches out.
Any programming software will work for you.
That or get a custom tune.
The Depth of the o2 sensor in the stream will effect things also. If you get codes, sometimes you just have to shave a little off the o2 sensor bung to allow the sensor to go more into the exhaust stream. Some sensors are longer than others.
EFILive, hptuners, tunercat, Jet, ls1edit, will all do what you need to do. It would be a MUCH easier way to go from your choice of wanting to pull out the factory computer and go aftermarket......
