put in new plugs, fuel trims off...help?!
ok i put in new plugs, i had a problem of running lean before and figured i might have messed up some plugs. well it fires a lot better now but here is the thing. before i would go out and the mV on the o2 read 870 and now they read about 900. the fuel trims were at about -1.56 or -.78 and now they went there once but then went right back to aobut -6 or so. will it just take time for the computer to adjust to the new plugs? should i just check again in about a week or so? just wanna make sure thats normal
Originally Posted by WS6FirebirdTA00
please guys, im gonna run at the strip tomorrow just wanna make sure its not gonna hurt anything
Did you disconnect the battery. It might be re-learning.
I presume you are talking LTFT's. If it's STFT then the computer is simply relearning. If LTFT's are positive, then you are probably running lean, negative - rich, 0 - perfect.
Also [obviously] at WOT you only need to pay attention to WOT cell (#22).
ok thanks for the info. no i didnt disconnect it yet. i jsut wanted to make sure it was relearning. now here is another question, if the fuel trims went from -6 to 0 would that make the WOT fuel leaner?
If the ltrims changed on their own it would not effect WOT.
