my SES light is on for mass air flow low circuit input does anyone have some insight on what it could be?
Get a scanner on it and see if there is a output signal from the MAF when the car is running, if not the sensor is dead. It should read anywhere from 2,500-3,200hz at idle.
You sure the eng sensor fuse is good? Probably wouldn't hurt to change it anyways. I just had the same problem I swapped the maf and cleaned the replacement and same thing. I pulled the fuse and it was hard to see but sure enough it was blown.
