Little lean? Too much timing?
I'm gonna buy some TR6's regardless to throw in there.
Thanks Wayne. Unfortunately, the only pulls I can make are on the street. I've got to find someone here in Oklahoma City with HP Tuners so I can log some stuff and send the file to Jeff. Or find a good tuner around here. No luck so far.
Put the 6's in made a 3rd gear pull... shut it off and post pic of plug.
You know, I've contemplated just buying the tuning software and wideband and doing it myself, but that **** isn't cheap. I'd actually prefer to learn, but just dont have the cash right now.
it may not be rocket science, but i just bouight my hpt 2 or 3 weeks ago and i'm pretty lost. i'm still playing in SD... and havent got that quite figured out.
i even bought greg banish's first book and that didnt help a whole lot, mostly just calculations and history of an EFI motor
Its impossible to tell whats going on with a used plug but right off the bat the base ring is black with something. I can't tell by the pictures but it looks like oil, if its fuel than the normal part throttle/idle fueling is too rich. If its oil the engine is using some oil. You are going to need a otoscope to check down at the base of the ceramic to see what the fuel ring looks like. You'll also need to put a fresh plug in, make a pull then shut it off to be able to accurately read the ground strap.
