98 pcm help
Old 10-31-2009, 11:04 AM
19trans_am98's Avatar
Default 98 pcm help
is there anyway to run a 00 model comp. with a 98 wiring harness?
Old 10-31-2009, 10:20 PM
ND2RACE's Avatar
In short no. The harness can be re-pinned, but IMO is too big of a PITA. You could install a 99-02 harness and do a full reflash on the 98 PCM. The PCMs are teh same just having a different pin-out.
Old 11-01-2009, 07:02 AM
slow's Avatar
you cannot flash a 98 pcm with any other year OS of you will kill it, you need to replace it with a 99-00 or 01-02 pcm
Ryan
Old 11-01-2009, 09:04 AM
Doc
Doc's Avatar
Not that big of a deal when you have done it as many times as we have.
Old 11-01-2009, 12:13 PM
DeanJ's Avatar
Repinning the harness ain't that big of a deal. A lot easier than changing the harness, besides you already have a harness. Reflash of 98 PCM wont work. Dean.
Old 11-01-2009, 12:19 PM
DeanJ's Avatar
Repinning the harness ain't that big of a deal. A lot easier than changing the harness, besides you already have a harness. Reflash of 98 PCM wont work. Look here for the pinouts. It looks like a lot, but it isn't that bad. You will be happier with the later PCM.
https://ls1tech.com/forums/conversio...swap-faqs.html
Old 11-07-2009, 08:46 PM
cccullins's Avatar
Does the 99 and 98 pcm use the same harness connector and are any special tools require to unpin connector, thanks
Old 11-07-2009, 10:19 PM
allan808's Avatar
i got a 98 TA whats the benifet of going to a newer model pcm?can i just have the 98 pcm tuned for the mods instead of changing it all out then get tuned?
Old 11-10-2009, 12:59 PM
jegten's Avatar
thanks for the info.
question-if i have a 98 camaro i am wanting to mod, i.e., heads, cam, injectors, tune accordingly, will i be better off changing to a later pcm, if so, what year pcm?
again, thanks!
Old 11-10-2009, 01:33 PM
Boosted One's Avatar
It all depends on the extent of your mods. I'm running 10.2 with a 98 ecm so It can't be all that bad. The only reasons I see to change it out are either adding Boost, or really aggresive heads/cam/high compression. So in short, unless your adding boost or building a race car your good to go.
The later pcm have it's advandage in that they are easier to tune using a c.o.s. and they are faster with better resolution. But it's unlikely any of that would equate into HP in a typical heads/cam car.
Frank
