Looking for a new wide band, have some questions
Old 11-04-2009, 01:49 PM
rickou812's Avatar
Default Looking for a new wide band, have some questions
I have what I guess was one of PLX's first wide bands. It was the 3" x 4" x 1" black box with the red LED readout on the front. Anyway, it decided to take a dump.
I need to replace it, but I would like a simple gauge that has a play back function. Like play back tachs do.
Is there anything on the market that fits this bill?
Thanks,
Rick
Old 11-05-2009, 02:23 PM
1CAMWNDR's Avatar
Hmmmm I don't know about playback function. You know I am pleased with my Innovate LC-1 and simple digital gauge. The hard part about playing back the O2 is you will not be able to tell what rpm and kPa you were at .
Old 11-05-2009, 03:03 PM
rickou812's Avatar
It would be useful for track use. After a 1/8 or 1/4 pass, I would be able to replay the run quickly and easily to see if the tune needs richening up or leaning out, especially if spraying.
I actually think I have found the the new FAST wideband has this capability as well as RPM.
But it is on the pricey side, still researching it though..
Old 11-05-2009, 04:44 PM
firehawk81's Avatar
you can use the AFX with HP tuner pro and you can scan and record with analog out put for the drag race that what i do when i go to the track .
or you can go for devi gages that has recorder in it . but with out having a scanner to show you what RPM you at at deferent load you wont going to be able to adjust the tune .
Old 11-06-2009, 02:59 PM
1CAMWNDR's Avatar
Yeah, but he doesnt have HP Tuners. If he had a '99 or '00 I would be able to scan it and tune it.
Old 11-06-2009, 04:25 PM
rickou812's Avatar
I am going with the new FAST duel wideband with a RPM module. It has onboard datalogging capabilities and also can playback in vehicle with out laptop..
Old 11-06-2009, 05:05 PM
JonCR96Z's Avatar
You can still scan it.
Old 11-08-2009, 09:17 PM
1CAMWNDR's Avatar
Yeah, I can scan it. But I can't tune it, and the '98 doesn't have as nice of a VE table, and I can't go with him every time he goes to the tarck to scan the car and try to convert the information into something you can use on LS1Edit.
I hope this wideband lasts longer than the last one. Maybe we can get the lean tip in problem knocked out when I am not on-call.
