Random Cylinder Misfire Code after Cam swap
Moderator
If it's truly random that is probably just the cam lope
exceeding the misfire detect threshold. If you double
all the cylinder mode misfire values that aren't already
"dummied", it should settle down the bitching.
But you should look in the logs at Misfire Cylinder 1-8
for any signs that the misfires are "bunched" in some
cylinders, which would point to some imbalance in fuel
or spark.
or spark.
