Diablo Tune
Diablo Tune
Hey guys i just picked up my Diablo Predator today and i was wondering if i should modify any of the parameters and then start logging. My mods so far are Pacesetter LT headers, high flow cats with X pipe, K&N CAI, BBK 80mm TB. I was wondering with the mods if im going to need to add more fuel and timing.
Thanks for your help.
LS1Tech Sponsor
do some logging... that will show you where your average LTFT's are and what you need to adjust your injector slope to in order to get the ltft's dialed in to the proper range of 0 to -2...
http://diablosport.com/index.php?nam...iewtopic&t=917
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
did you buy the predator brand new? what revision is on it? when it boots up and is at the main menu, there's a number at the top of the screen... that's the revision number... what is it?
if it's a newer 9rXX revision, you can record/save data logs and connect to your PC to download them with diablo's DataViewer app.
if it's an older 2.XX revision, you can NOT record/save data logs, and can only view the data live on the predator screen while you drive.
do a steady drive/cruise on the highway, so that your rpms are between 1800-2000...
at the end, take the average of the ltft's... then adjust your injector slope the opposite amount...
the info on how to do it all is at that link I provided above...
and if you want, I can even take a look at the log files for ya, provided you have a newer one that can save the data logs.
__________________
LS1Tech Sponsor
LS1Tech Sponsor
and besides the power adapter Mike mentioned above, you also need a usb-serial cable in order to actually hook up the predator to your Windows PC...
if your ltft's averaged 11.5, modify the diablo tune you have installed and adjust the injector slope to -12%...
__________________
LS1Tech Sponsor
well, you can try adding some fuel in the rpm range where you're getting the KR, or you can pull some timing...
what's your AFR at WOT??
__________________
