1999 Camaro Fuel Gauge not working after 1998 tank install
Old 01-30-2010, 05:22 PM
ABeasst's Avatar
Default 1999 Camaro Fuel Gauge not working after 1998 tank install
I installed a sumped 1998 fuel tank into a 1999 Camaro. I need to know what values in the computer need to be changed to make the 1999 fuel gauge read correctly.
Thanks
Old 01-31-2010, 06:07 PM
ABeasst's Avatar
bump anyone know which tables to change?
Old 01-31-2010, 06:25 PM
GregRexAdams's Avatar
You would have to get a 99-2002 tune with a 98 fuel area segment swap. Best way is to get a 2001-2002 so you have adjustability of the IAT-ECT bias and no secondary VE table.
Old 01-31-2010, 07:53 PM
shoemike's Avatar
You can't swap segment between non-matching OS'.
I believe what is done when converting a 98 to 99+ PCM is a segment swap with
an Express Van.
Is the fuel tank unit from a 98 as well?
If not I wouldn't think anything would need to be changed.
Old 01-31-2010, 08:16 PM
ABeasst's Avatar
Yes the tank and sending unit are from a 1998 camaro.
Old 01-31-2010, 08:39 PM
shoemike's Avatar
Post #3
Old 02-05-2010, 11:13 AM
shoemike's Avatar
Any progress on this?
Old 02-05-2010, 12:15 PM
ABeasst's Avatar
The only way I've been able to get the fuel gauge to register anything was by raising the primary fuel volume. I wasnt able to use the above post since I'm using HPT instead of EFI Live.
Old 02-05-2010, 01:00 PM
shoemike's Avatar
You have to have the people at HPT do the segment swap for you.
Fuel Segment Swap??
Old 03-10-2010, 09:10 PM
ABeasst's Avatar
I got this fixed without doing a fuel segment swap. I just scaled the primary and secondary fuel volumes from 0-90 ohms which is what the 98 sending unit reads. The 99+ reads from 40-250 so the range is the computer goes from 0-250 so all I had to do was start the fuel volume at 0 instead of 40 and end it at 90 instead of 250.
Quick Reply: 1999 Camaro Fuel Gauge not working after 1998 tank install
