What is trouble code PO154?
Old 01-12-2004, 09:35 AM
Larry's Avatar
Default What is trouble code PO154?
Installed Pace Headers and got a PO154 trouble code. Can't seem to find a trouble code chart.
Old 01-12-2004, 09:53 AM
2002WS6_MN6's Avatar
P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1-A
Old 01-12-2004, 09:54 AM
2xLS1's Avatar
HO2S Circuit Insufficient Activity B2S1
Old 01-12-2004, 09:59 AM
Larry's Avatar
Thanks! What do I do to fix it?
Old 01-12-2004, 10:03 AM
2xLS1's Avatar
Did you use O2 extensions or splice into the harness and extend it? Check the wiring on the pass side front O2 sensor.
Old 01-12-2004, 10:09 AM
Larry's Avatar
Pace Setter supplied wire to extend the sensor wires. I spliced in these wires and soldered them together.
I'll take a look at the wires but don't see that I have done anything wrong as far as my splicing and soldering.
Old 01-12-2004, 10:12 AM
Insufficient activity could be a problem with the heater circuit. If you have a scanner you need to monitor the sensor voltage while in closed loop.
The EFILive charts would be nice so you could compare the sweeping of B1S1 and B2S1..
Since you did headers check and double check the wiring harness and connectors to the sensor. Look at the pins and make sure they're not pushed in.
If everything looks good you may need a new sensor.. You could always swap B1 with B2 and see if the code move to the other bank just be be sure before you spend $80 on a new sensor.
Old 01-12-2004, 10:22 AM
Larry's Avatar
I cleared the code out and no SES light at idle now. I'll take it for a drive and see if it comes back on. If it does then I'll swap out the sensors like you recommended and see what happens.
Old 01-12-2004, 10:32 AM
2xLS1's Avatar
Splicing into the sensor leads is not a good thing to do. It is better to extend the wiring harness on the car if you are not going to buy extensions.
Old 01-12-2004, 11:44 AM
Larry's Avatar
Looks like I need to buy the extensions if splicing is not going to work. Why did Pace Setter supply wires to splice if this doesn't work?
The SES light came back on after I cleared it. Engine runs terrible. Misses bad.
Old 01-12-2004, 12:03 PM
Splicing will work.. A quality soldered spliced connection will work fine..
Notice the word quality.
Make sure you use some shrink wrap to protect the connection.
Old 01-12-2004, 12:04 PM
Remember this is a milivolt sensor.. the slightest resistance in your connection will cause problems..
Old 01-12-2004, 01:10 PM
Larry's Avatar
That just may be the problem. My solder joints are kinda puny.
Old 01-12-2004, 02:26 PM
Larry's Avatar
Purple wire, passenger side pulled apart. Bad solder!
Can always rely on the guys from LS1 Tech to help. Thanks guys!
Old 01-12-2004, 03:31 PM
Team ZR-1's Avatar
O2s need outside air to reference to.
The O2 wires are special so they have a airchannel inside them to get that outside air at the O2 connector where temps are cooler.
Without that the O2 cannot function correctly.
Splicing will cause O2s to act weird and false readings to PCM so I would not spice at all.
Old 01-12-2004, 04:33 PM
2xLS1's Avatar
Like I said above, you do not extend the O2 sensor, you extend the harness on the car. Thank you TeamZR-1 for backing me up on this.
Old 01-12-2004, 04:45 PM
Larry's Avatar
Thanks! Looks like I may still have a problem. Better go get me an extender.
I'll give it a test drive next and see what Auto Tap says.
Quick Reply: What is trouble code PO154?
