going from maf to speed density tune
Old 07-21-2010, 07:28 AM
doin-work's Avatar
Default going from maf to speed density tune
I am looking to go with aon my current build but I don’t know how can some one help me or steer me in the direction where I can find this info
Old 07-21-2010, 10:09 AM
Phil'sC5vette's Avatar
You may have to tell us a little more about your car and set up.
Do you live in an area where the weather never changes?
Old 07-21-2010, 11:58 AM
wait4me's Avatar
in efilive in the help tab, then go to custom os tutorial, it helps with most of the things needed when you change over to sd.
www.efilive.com
Old 07-21-2010, 07:43 PM
doin-work's Avatar
i live in south florida so its always hot there isnt much change down here im going with a 383 bottom end ported ls6 heads a mild cam with a fast 102 mm intake and a 150 shot
Old 07-21-2010, 07:50 PM
BLK02WS6's Avatar
I would go with EFILive, custom operating system 5 - then you can go speed density and control your nitrous timing all in one convenient package...
Old 07-21-2010, 07:57 PM
brianfromhawaii's Avatar
even if the weather changes a bit, SD is great... look how many cars run SD and are FINE!! my yamaha r1 is SD and puts out 180hp... and i ride it on hot as **** days, pouring rain and freezin cold in the mountains.
SD is THE ****!
Old 07-23-2010, 09:35 PM
joecar's Avatar
Basically, remove the MAF, and during tuning you disable CL/trimming, and use wideband lambda to correct the VE table.
Then for street use, you can enable CL/trimming, or for race use you can eliminate the O2's.
+1 on COS5... it's very versatile (nitrous, boost, SD or MAF, OL or CL, Alpha-N).
COS5 needs a 0411 PCM.
Old 07-26-2010, 09:41 PM
white01ss's Avatar
Running EFILive's COS3 which lets you to easily switch between front O2s and SD at any MAP & RPM cell. Used the front O2s for a while with the stock cam but after the blower cam the AFR was all over the place. I could hear and feel the motor oscillating rich to lean... very annoying even with the average AFR where I wanted. Switched to 100% SD and it was so much smoother and gained a few mpg not that it matters.
Quick Reply: going from maf to speed density tune
