Turn off VATS/Security
Old 04-03-2011, 12:14 AM
firemech21's Avatar
Default Turn off VATS/Security
I did no work to my car today and went to start it and nothing. After testing the VATS/Security system nothing is working and car wont start. If i put the key in the ignition and turn it to "start" the security light comes on and starter wont engage. If i keep the key in the run position and wait for the light to shut off, the car fires right up and will run/start as long as i dont lock the car. Any help would be great please give me something. Can the VATS or security system be shut off inside the computer????????
Old 04-03-2011, 10:52 AM
firemech21's Avatar
Does anyone have any ideas?
Old 04-03-2011, 12:11 PM
LS88FoxBody's Avatar
You can shut vats off with HP tuners. If that's what you mean inside the computer..
Old 04-04-2011, 12:06 AM
01ssreda4's Avatar
will start and run as long as i dont lock the car
Can you explain this further? And yes VATS can be tuned out very quickly with HPTuners or EFILive.
Old 04-04-2011, 06:51 AM
firemech21's Avatar
What was happening is if I started the car using the above process it would work. If I shut it off and pulled the key out or locked the doors it wouldnt start again. I changed out the key cylinder and ignition switch (PITA), this seemed to fix the issue. When i go to get my car tuned for the cam and other parts Im putting in it I want them to disable the VATS though.
Old 04-04-2011, 07:29 AM
safemode's Avatar
Why didn't you just do the 99cent bypass if you're going to disable vats anyway?
Old 04-04-2011, 01:26 PM
Frost's Avatar
That's for swaps; tuning the PCM doesn't eliminate the BCM from the car, it's key-check, or it's starter disable. Tuning out VATs just tells the PCM not to cut off fuel in the absence of a BCM and/or it's signal.
Old 04-04-2011, 03:11 PM
safemode's Avatar
sounds like it was a key cylinder issue since it was fixed when he replaced that. So a 99 cent bypass was all he really needed and never have an issue with the key check again. 99% of the time that's all that ever fails in a vats system anyway.
Old 04-04-2011, 09:00 PM
shepss217's Avatar
my car just has the security light on, it just started doing this today, hasn't left me stranded yet, i'm going to buy a new ac delco key lock cylinder, found 1 for $50, do i have to take it to a dealer after that?
Old 04-04-2011, 10:52 PM
red 95 t/a's Avatar
My trans am did this the other day. I scanned it with our snapon scanner and it set a theft code and i couldnt get it to clear out. I unlocked the door with the key and hasnt done it since. I dont know what the hell was up with it.Hasnt done it since lol.
The wifes 2000 v6 camaro security light has been on since we got it. Whats the 99cent bypass?
Old 04-05-2011, 07:40 AM
safemode's Avatar
take the resistance of the chip in your key. goto radio shack. Spend 99 cents on a resistor pack that matches the resistance or a combination of resistors that do. Solder them in place of the wire going to the key lock cylinder that contacts the chip in your key ... done. Now your VATS always reads the correct resistance no matter what the lock cylinder reads.
it literally takes about 5 minutes and about 99 cents. Completely invisible and wont wear out.
Old 07-03-2017, 12:04 PM
5.7stroker's Avatar
Back from the grave. I have VATS disabled through HP tuners, but when the car is in park with no alarm on, the battery gets drained just from sitting after about 5 days.
Should I bother checking to see if their is a drop in mA when a certain fused is pulled or is this a common problem related to VATS and BCM?
Old 07-06-2017, 10:09 AM
rpturbo's Avatar
Car should be able to sit 5 days no problem. Yeah, you have something you need to look into.
Old 08-10-2020, 10:13 AM
Ryan Hart's Avatar
5 days battery dead, mine does this because of headlight won't return to rest position, you can't see it. Just unplug it til I can fix it.
Old 08-10-2020, 12:16 PM
5.7stroker's Avatar
Installed a battery cutoff switch. Problem
solved lol
Quick Reply: Turn off VATS/Security
