pros cons of removing maf
can someone help me decide whether or not to tune my car to speed density? whats the difference and what are some draw back if any. im runnin the 98 ws6 in my sig, only this year i put on the ls3 top end with a 92mm throttle body.. and im stuck between buyin a bigger maf or just havin it tuned out. any advice would be great
Mf vs Sd
I say dont over think it, almost like saying is chevy better than Ford depends on what you like, if you have your air fuel ratio down and tuning parameters where they need to be they both work great I have run my car both ways and happy either one. street I like Maf all out racing still running SD but doing maf tune right now and had before and ran same numbers. If tuned correctly you will be happy either way in my opinion SD tuning easier to do Maf takes a little more time for me.
So far so good, no real issue, cars driven to shows but mostly taken to track so outside temp are pretty stable lol I Like maf tuning better myself just my preferance especially for startup and my AFR seems more accurate at wot, but will see how cars runs on maf tune only at track verses the SD did that last year no real big change but alot of motor mods over winter so want to see any differance now with so many mods
I should have my new 98mm FTP lid and silicone coupler in on monday and then get the FROST SD tune put on my Formula. I'm told that SD has snappier throttle response and I'm all about that. Will report results later....
Remember, there were lots of production cars that were stock speed density before the MAF set-up became popular. And even with their very primitive computers the cars ran excellent for that technology IMO. I would not fear the DD ability of a SD car tuned correctly.
Between cold (25°F) and hot (90°F) days my WOT AFR swings ~.3-.4 points with a SD tune. The bigger problem isn't steady state, but heat soaks from sitting in traffic at idle or when restarting after the car sits for a short time period. In those times I'm leary of going WOT because it's so lean, but that's more a factor of the terrible temp sensor and not the tuning. Throttle resposne is definitely snappier/crisper SD, but the car smoother across more situations when tuned with the MAF.
So true ramair. For SD you have to tune for the leanest condition possible. That means summer heat, sitting in traffic, A/C on and both fans running. Then in the winter with no fans or A/C it runs rich on the summer tune but not too bad. Non idle ranges aren't impacted as much as near idle.
