When braking lightly on dry road, ABS engages?
Old 02-22-2004, 02:45 PM
bomax's Avatar
Question When braking lightly on dry road, ABS engages?
The only thing I can think is that either a) one of my ABS sensors is damaged, or B) Since I put on the new tires (which are taller ET Streets) I need to adjust in Edit the new tire height. The PCM is somehow getting confused about the speed/tire rotations (due to the taller tire) and engaging ABS.
And P.S. I know I need to change anyway so the speedo is correct, and I know I could have changed it in Edit in the time it took to post this but the car is 50 miles away and I don't have access to it until next weekend.
Old 02-23-2004, 06:55 PM
bomax's Avatar
ttttt
Old 02-23-2004, 07:42 PM
HumpinSS's Avatar
My car does that at the track with 26" ET Streets
Old 02-23-2004, 09:03 PM
felton316's Avatar
It will do that if you run different sized tires front and back.
Old 02-23-2004, 09:32 PM
bomax's Avatar
Is there any way to correct this?
Old 02-23-2004, 11:21 PM
felton316's Avatar
The outer dimensions of the tires need to be really close, otherwise it thinks the tire is out of control due to the difference in speeds. Same thing happens, when I try braking and a tire actual comes off the ground, the ABS computer goes ape-****.
Old 02-24-2004, 06:39 PM
bomax's Avatar
So, with ET Streets out back and stock F1s up front, there is no way to stop this from happening?
Old 02-24-2004, 07:51 PM
felton316's Avatar
Not unless the F1's are the same diameter as the ET streets. If the F1's are smaller, then the ABS computer will see them spinning faster that the rear tires.
