Service engine soon
Old 05-05-2011, 09:45 AM
JESTRADA's Avatar
Default Service engine soon
I have a 2000 TA and the 'Service Engine Soon' light has come on. I will run the scanner on her tonight, but was just curious if any one knows of any common problems?? Any info will help!
Old 05-05-2011, 10:23 AM
AwsmGy's Avatar
There's a huge list of codes, there's no way anyone will be able to help you without a description of the problem. You're basically saying "my car is broken, what's wrong?" and giving 0 details. The code will ultimately determine what you need to do to fix it though.
Old 05-05-2011, 10:28 AM
babbage1109's Avatar
Has it been running rough or idling weird starting up funny or bogging down?
Old 05-05-2011, 11:28 AM
ZexGX's Avatar
Sounds like the problem I have with my car: http://www.fbodyonline.com/forum/f8/hey-guys-164362/
Old 05-05-2011, 02:02 PM
rbaksi's Avatar
This thread is useless without the codes or any symptoms at all. Think before you post.
Old 05-05-2011, 07:22 PM
JESTRADA's Avatar
Default Code Indentified
Looks like we are looking @ Code #P0327 (Knock Sensor 1, Circuit Low Input (Bank 1))
Old 05-05-2011, 08:13 PM
Pete137's Avatar
Sooooooo.......do you still need help? Or do you got it figured out from here?
Old 05-05-2011, 08:20 PM
JESTRADA's Avatar
I think so... Isn't there 2 sensors on the intake.. If so i'll replace them both while I am at the one. Probably need to replace the intake gaskets also. But, I am not sure exactly what the sensor does, or it's purpose... or if I went a little while before replacing it, would it be alright?
Old 05-05-2011, 08:24 PM
JESTRADA's Avatar
Rbaksi - I was just asking a general question, it's not useless. Usually with F body cars, many of them encounter similar problems...hince to general question. Such a problem that usually occurs is the headlamp 'noise' and the flipping up and down upon lock/unlock and the fog lamps flashing... this is a TYPICAL problem. That's sorta why I was asking to see if there was a given... just like that.
http://www.youtube.com/watch?v=LOVqS7_Ca9A
Old 05-05-2011, 08:29 PM
Pete137's Avatar
Yea, but you only have a P0327 right? Not a PO332? I'm not an expert by any means, but it should just be the sensor on the driver's side.
But does it sound like your engine is running fine? Or do you actually have engine knock or any other extra sound coming from the engine?
Old 05-05-2011, 08:30 PM
TJFish's Avatar
That reminds me, I never got back to you on that plasma pressure regulator deal
Old 05-05-2011, 08:36 PM
JESTRADA's Avatar
Yep, just the P0327 - Nope no knocks, no odd sounds. It does seem to be running fine and strong. I was told this particular sensor may have something to do with how the fuel is regulated. So... I could be burning some gas!! And with these high prices! Don't want that.
Old 05-05-2011, 08:38 PM
SSickLS1SS's Avatar
i think you have one of these problems
http://www.youtube.com/watch?v=1wAUw...feature=fvwrel
Old 05-05-2011, 09:33 PM
AwsmGy's Avatar
The problem is, the headlight issue is very specific. What you did would be like the equivalent of going to a doctors office, telling them your sick, and then when they ask what's wrong you go "uh...iono". I'm glad you found out what you need, please be more specific next time though.
Old 05-05-2011, 10:11 PM
ZexGX's Avatar
It shows. The knock sensors on LS1 F-bodies are located in the valley cover, front/rear, not driver/passenger.
May as well buy two new knock sensors, and a new knock sensor wiring harness. Follow the intake manifold removal guides and like everybody says, be EXTRA careful around the oil pressure sending unit at the back of the intake manifold.
Old 05-06-2011, 12:19 AM
Pete137's Avatar
Well I guess it's good that I realize that I still have a lot to learn, better than acting like a know-it-all ricer. I didn't know the exact location, just that there was a sensor for each bank.
Quick Reply: Service engine soon
