what is the difference in ls1 and ls6 stock tune?
Old 05-18-2011, 08:37 PM
theskitztikwon's Avatar
Default what is the difference in ls1 and ls6 stock tune?
Other than rev limiter, and shift point how well will a ls1 converted to an ls6 with LT headers, ported t/b, lid run
Old 05-19-2011, 08:12 AM
SSpdDmon's Avatar
There's a bit of difference...timing tables, fueling, etc. Unless you do a complete swap (LS6 heads, LS6 cam, etc.), just modify your current tune.
Old 05-19-2011, 11:16 AM
Well I got a stock tune (other the the rear gears recal.)but I can adjust the rev limiter and shift point with with the hypertech programer I got. I am just trying to get bye till I buy a stall.
Old 05-19-2011, 11:24 AM
Frost's Avatar
Avoid WOT; the LS6 needs much less timing than your LS1 did, especially if your LS1 is a 98-00. It will knock.
Old 05-19-2011, 11:38 AM
Its an 02 atleast. But thanx for the info. And you will be hearing from me soon frost
Old 05-19-2011, 02:14 PM
ramairJP's Avatar
What Frost said. Even bolting on a LS6 intake required pulling 4-5 degrees.
Old 05-19-2011, 02:20 PM
Damn its an 02 so already have that. I sent frost an email, I think it will be in my best interest to go ahead and get it done im not sure when ill be getting a stall so I might as well bit the bullet.
