po650/ ses light not working
Old 07-27-2011, 05:34 PM
Lsexman's Avatar
Default po650/ ses light not working
I have a 99 ls1 b4c car. It is showing a po650 code along with a po332(?) It's a knock sensor bank 2 code. I have tried doing research but can't come up with anything on how to fix the po650 malfunction indicator lamp. My ses light does not work, hints the po650 code. First question is how can I fix this, I know it has to do with the pcm wiring but vet lost after that, I dont even know where the pcm is on this car. I looked under the dash and see a bunch of wiring so I assume somewhere around there? Secondly when I fix the knock sensor and it does not throw that code anymore, will the po650 go away since there will be no reason for the ses light to come on? I assume I can't have a MIL if its not being used. Eaither way i need these codes gone for inspection. So even if I can't trouble shoot the po650 code can I just "tune it out" with hptuner like egr and air codes? Thanks for all the help in advance!
Ps mods in Sig if needed
Old 07-28-2011, 05:48 PM
Lsexman's Avatar
Anyone?
Old 07-28-2011, 06:05 PM
2001NBMZ28's Avatar
Well two different things might happening here. Are they current or history codes? Here's what I'd do if you think the secondary air codes haven't been tuned out. Remove the AIR PUMP fuse under the hood and drive it for a few cycles - that should set the MIL and probably throw P0412.
Old 07-28-2011, 06:19 PM
Lsexman's Avatar
Current codes. I'm almost 100% sure air codes have been tuned out. I have no air, pump and hoses are taken off, and have never threw codes for air after dyno tune
Old 07-28-2011, 06:47 PM
2001NBMZ28's Avatar
Sorry, didn't see !AIR in your sig. If you still want to verify if the MIL will come pull something else - like ENG SEN fuse.
Old 07-30-2011, 10:43 AM
Lsexman's Avatar
Ses light doesn't work when I pull fuse. Anyone have any other ideas. I found pcm but failed at trying to follow ground wire. Anyone know where pcm ground wire is
Old 07-31-2011, 03:03 PM
Lsexman's Avatar
After hours of research I think there are 4 grounds? 1 on each of the heads on the back side. But where are the other 2? And how do I get to the 2 on the heads? Comon ls1techers help me out! Lol
Old 08-02-2011, 08:35 AM
Lsexman's Avatar
Bump still trying to find locations of ground wires for pcm.
Old 08-02-2011, 10:39 PM
Lsexman's Avatar
To the top
Old 08-04-2011, 12:04 PM
Lsexman's Avatar
Any ideas?
Old 08-05-2011, 02:24 PM
Lsexman's Avatar
To the top
Old 08-06-2011, 11:37 AM
Lsexman's Avatar
I know someone here knows where pmc grounds are! Lol
Old 08-06-2011, 04:46 PM
2001NBMZ28's Avatar
Internal ground within the PCM maybe? Did you visit gearchatter? www.gearchatter.com/viewtopic8832.php You may need to pull the connector.
Old 08-07-2011, 11:47 AM
Lsexman's Avatar
Yea i think I have that page memorized. I just get a little lost when it comes to electronics and schematics :/ any idea where internal pcm grounds are located and the color? Thanks for the input!
Old 08-10-2011, 12:47 PM
Lsexman's Avatar
To the top
Quick Reply: po650/ ses light not working
