error $0331 when reflashing
Hi,
I'm getting an error $0331 when attempting to reflash the e38 after getting a post datalogging retune. I'm using an EFI LIVE Autocal. Any help greatly appreciated!
http://forum.efilive.com/showthread....934-Error-0331 search a little dont know if it helps your problem or not
I should have mentioned I did a google web search, efi live forum search, corvette forum search, digital corvettes forum search, smokin vettes forum search to no avail prior to posting the thread.
Manually Install the new versions of V7 and V8 (do not do the automated update) , then flash the new bootblock/firmware into your V2
(there are new versions as of yesterday)
Then using V8 S&T read the BBL/BBF settings from your V2, and program them back into your V2.
If you have a manual trans, then make sure that no TCM is mentioned in the BBL/BBF settings.
