PCMForLESS?
PCMForLESS?
Got a 418 ls3 im going to need tuned soon. Has anybody used PCMforLESS, where you send them your computer with all of your engine info and they tune the computer for you and send it back? If you have were you happy with it or do you wish you would have just taken the car to a tuner?
pcm4less is the **** bro had two pcm's to another tuner that is well known and when i received pcm's back neither was right and car wouldnt move or run good and tuner said it was something i did in wiring the car well long story short i took one of the pcm's to pcm4less got it home and installed it car ran great n moved then went and meet bryan herter at sarver performance and he did full dyno on car he is the only one i trust with the tuning now
Brian Herter from PCM for less is a very good tuner. He can get you up and running via the mail, but with that build, I think to get it right, you need to get it on the dyno. Brian travels all over the place and I'm sure if u contacted him you could hook up at a local dyno shop that he is affiliated with and have him tune it for you.
Bryan (PCM for Less) Tuned mine also and it's fantastic. I hav a turbo charged ls3. He sent the first tune to me and I drove it a little and gave him info on what the gauges were reading and then sent it back and when I got it back the second time it was perfect. 300 bucks total charge. Needless to say I'm very happy.
I would not use them again. I had them Dyno tune my car and it died on me all the time. I called them several times and they recommended drilling a hole in my throttle body plate. This did not work either. I had the car re-tuned by someone else and it runs quicker, smoother and the idle is perfect. (No more stalling at every light)
