Holley Domitator EFI users
I am in the process of buidling a twin turbo LSX 67 camaro and now need to decide on a computer system. I have been researching the Holley system and it looks good. Who is using it and how do you like it? Any pros/cons? I am running a 4L80 so I want it to control that also. Thanks for any replies!
Restricted User
http://www.youtube.com/watch?v=n3oJpcz409g&feature=fvst
[QUOTE=98Z28CobraKiller;15533866]Finished enough to go 7.87 @ 180. Race cars are never "finished". What do you want to know?
You mentioned in the other thread a problem with the stock coils. Are the Holley coils the only ones that will work right? I had been planning on using MSD's. Are there any other big problems you have come across?
Restricted User
Regardless of what engine management you decide to use, I highly recommend that you do some research on the MSD coils. From everything that I have read, those things are junk.
It's weird because we have another buddy that is running relocated truck coils on his Silverado w/ a 408 LQ9 and a PT94 that has had not one hickup up to 12psi so far with his Holley HP ECU. All 3 of the fbodies that we have the Dominators in did not like the stock coils. Regardless, the new ECU's, with redesigned boards, are very close to shipping, from what I have understood. The issue is simply that the ignition cuts out randomly under WOT acceleration. The Holley coils are solid and resolve the issue.
Any more input on the Holley Dominator setup??
Restricted User
We just got the last box of parts that we needed in order to hook up the boost control in all 3 cars and also just got all the software to make it work. We are all using CO2 for "dome pressure" control (top port on the wastegate). They have not done any real world testing this way yet (w/ CO2). We will be providing feedback directly to Holley first and will report results once any issues are addressed or resolved. Not fair to post a play by play on a prototype as if it were finished product.
The Holley 120's that I am using resolved some major problems taht I was having with the Bosch 160 low imps at idle and part throttle. You can't beat them for the price.
Is there a way to make this work with a external crank/sensor like the 24tooth BS3? I do not have the internal reluctor. This sounds like the way to go once the boost control is ready.
Sorry for the hijack.
