Not making power on nitrous
Spraying 150ish? dry. Hits like a mad man on the initial hit then falls flat. On this pass, I spun out of the hole, got planted and hit it. Let off for 1-2 switch, hit it again in 2 but it didn't pull hard. Let out middle of 2, hit it again in 3 and had nearly nothing there. Ended up going 11.6@119 with a 1.81 60'. Previous pass on motor went 11.80@112 with a 1.55 60'. Pass starts 2 mins into the log. 12.0ish AFR most of the way down and going fat up top. Any ideas?
