holley HP EFI short install, and a little how to
i installed the system a few weeks, ago and it worked out to pretty sweet.
the box it came in
pulled the camaro's harness out of the miata
he new system. it's just a file img. i was so excited to get it i didn't take a picture until i had it installed. mind you after i had the old harness out it was about 20 mints till the new one was in.
you can see the system removes the MAF sensor. it tunes usng the map. with the removal if that sensor and the general smaller size of the new kit the miata lost 15lbs.
i anchored the ecu down as close to the battery as i could. personally i think it looks sweet there. i didn't want to hide it under the dash.
after in installed the little ls1 powered miata gained a few hp but the mpg went from 23 to 33mpg. And the self tuning is bad ***! it makes everything a bolt on. i'm waiting for a call from texas speed about a set of heads
i looked high and low for the ls1 knock sensor frequency, ive seen allot of topics looking for it with no real answer. here it is it's 6khz
i left allot of how to set up the system on my web sight. i figured everyone would get bored reading threw an instruction book,
Nine Lives Racing JohnnyCichowski.com
the box it came in
there are allot of reasons why i switched. the ease of upgrading is probably the biggest. my little miata is going to have allot of parts thrown at it. headers, intakes, restricter plates, ect.. and going to a dyno after every part will cost me an arm and a leg. the HP EFI is going to save me a ton of $$.
for racing... track conditions change allot from event to event and i need to have my car running the best it can all the time. with out the Holley EFI: unless i have my tuner at the track with me i'm screwed!
it's ligher too. an important thing for racing. i think i listed a thousand reasons on my websight. i'm just bummed it's cold/snowy out and i cant drive my car.. after the ecu swap it's the most fuel efficient car i own
I am using the Holley hp on my rx7 and BMW with ls swap. I like the Holley system much better than factory system. Love having self learn and WB02. #1 reason for me was racing at tracks with different conditions and altitude, my tune is always perfect.
Let me know if you need a file for your engine.
Mike
Mike
Tuning of a VE table is completed as a noob with 8th grade reading comprehension in 15min. using the below...
Hp Tuners Pro $650
NGK AFX wideband with NTK sensor $250
"The Tuning School.com" Learn to Tune at Home Beginners Guide written for Hp Tuners $450
"The Tuning School.com" Learn to Tune at Home Advanced Guide written for Hp Tuners $480
Total: $1,830.
vs.
$1,500 for Holley EFI HP
+$250 for a wideband
Total: $1750.
I would rather have the knowledge, control, and understanding of the "how-what-why" my tuning results are occurring.
Hp Tuners Pro $650
Total: $1,830.
vs.
Total: $1750.
Downloaded and installed the software for the Holley EFI HP system off their website.
Then read thru the instructions in the HELP menu...
If you can actually get someone who wants EASY to read thru it all you could actually acquire an intro to how EFI systems and Speed Density tuning works.
I'm still not sold.
To each his own.
I'm still not sold.
To each his own.
Interesting! Thank you for the udate! BTW, thanks for the link. I read it. I have seen a lot info on the Holley EFI systems and it has many pros. It does have controls for fans and AC stuff too correct?
the 2 wire non resonant knock sensors... are not just generically a frequency of 6k... it is dependent on bore size...
the 1 wire resonant knock sensors are a fixed value for all engine sizes and the frequency is determined by the knock sensor itself...
an excellent article that anybody can use to get on the right path with knock sensors
http://www.chevytalk.org/fusionbb/sh...hp?tid/249317/
it controls Fans...uses either a ground, or a Hot....our fbody cars use a ground to activate and the relay is hot all the time.
AC is still controlled with the stock dash controls...
all you really need to do is to run a wire from the dash controls +12 signal for AC engagement out to the the wire on the compressor itself to engage the clutch...
other than that...nothing is needed...
if you want to get a little more complicated, a little safer, and a little more like stock..you could wire up the pressure switch to the holley, and have the holley output the +12v when the pressure is below a set pressure... and that can be your pressure safety switch.
you would then take the +12 from the Dash ***** over to teh holley first to activate the circuit.
Hey
Im looking for more tuning info for the hp. They have some forums for holley hp where you can ask questions, but it is not a self tutorial, where are you guys learning about their stuff on tuning with their software.
http://forums.holley.com/forumdisplay.php?49-HP
I guess my questions are for hooking up the stock camaro fans with a negative ground. I guess I need a step through for how to configure them both. If I have 2 relays which wire will go to fan and which wire goes to the holley ecu
Would the number 87 be going to red wire for fan and then ground the black wire. Currently my ls1 factory harness modified by current performance has built in relays.
tuning is not self explanatory... If it was... everybody would do it themselves...
you learn from reading and research, and possibly paying somebody to teach you how to tune..
figure out your specific issues that you want to solve...start using google to research...
read the forums of tuning software companies....HP Tuners/EFI Live/Tunercats/etc
they may not be the software you are using, but the same basic principal applies.
again... there is no self tutorial....
and it is not easy to tune properly...
I personally dont give out a lot of higher level tuning info, because I have over 15 years of EFI tuning Experience... I charge for my time and my info as do many others
Steve Morris, has a Holley tuning video,and some other tuning videos on his site.
I talk to him every year at DragWeek, he always has some of the baddest cars there, and has helped me with some tuning problems in the past.
http://www.stevemorrisengines.com/st...y-efi-dvd.html
Check them out, at his site. He is usually pretty helpful.
