How to pull timing hp tuners
Looking to retard my timing on my ta enough to run a 150 on it which I need to take a total of 5-6 degree of timing total out I have hp tuners does anyone or can anyone show me a step by step on how to remove the timing for it
Well it's a lil bit more to it than just that feel free to pm or txt me ... 8322161143
You need to log the car but you will be modifying the low octane , high octane and max timing tables under the spark tab...
BUT... You really need to read the plugs after each pass until they look good !
For a wet kit, I'd make the change in the high/low octane table. IAT table won't work because you're spraying behind the MAF/IAT sensor and it'll pull timing from all conditions (idle, part throttle and full throttle). You need to log where your car is (grams per cyl wise) at WOT and make the changes in that region of the high/low octane timing tables.
