code P0123....Help at track
1 Post
Might be that the throttle is opening too far - can you log TPS voltage? It can't go over 4.8V at WOT... Is there any chance the throttle body throttle stop is bent or something allowing it to open farther than it should? is it a stock throttle body?
1 Post
Don't know anything about that TB, but if you open it all the way, is there a stop? if it is able to be bent to keep it from opening so far, that may do it... possible it is just a bad TPS sensor too...
1 Post
Is the stop like a stock TB where it could simply be bent to keep it from opening so far? Just thinking if you are at the track, that would be a simple fix to get you running again...
Only thing I notice is there is only one cable on it instead of 2 like my friends stocked. It has a place for the "outside" cable, but no cable. Are both for the throttle or is one for something else
1 Post
Another thing you might be able to do - to keep from changing the idle setting - is to put some tape around the stop area (arrow) to keep it from opening as far... of course this is a temporary fix while you are at the track tonight...
No, It didn't have an adjustment for WOT, just idle.
I borrowed a stock TB to put on the car that night at the track and it ran fine and gave no codes, even picked up quite a bit.
I bought a used TB and put it on last night, but it's idling a little high. Gotta figure that one out now. I really appreciate your help the other night.
