TC or tune
Old 07-23-2012, 07:30 PM
BOTTLE ROCKET's Avatar
Default TC or tune
Coulld this be a torque converter or tune? My wifes C5 H/C A4 with 3200 stall is giving me a couple of problems that I cant seem to tune out
1. In 4th gear, when the TC locks up, it feels like it is constantly engaging and disengaging causing a "skip" feeling. I can shift back to 3rd, ands it is smooth as slilk so its not a skip. I can move the lock up around and it moves to the spot I set it.
2. After installing a set of heads, I was tweaking the tune and it mysteriously has lost all of it's low end punch. When I go WOT from a dead stop, it bogs really bad. I have tried several different timing settings but it still seems to bog just like the stall is not working.
Any thoughts?
Old 07-23-2012, 10:18 PM
ScottyBG's Avatar
As for #1 it may be the PWM, if you have not already, you may want to set that table to 100 all the time? Its probably better for your converter too. I had a similar problem to #2 with my camaro, and it was ASR (traction control) related. You may want to try pulling the fuse on the traction control and see if that has anything to do with it. My car picked up 57 MPH in the 1/4 after pulling the fuse. From bog to blowing the tires off.
Old 07-23-2012, 11:02 PM
MontecarloDrag's Avatar
Sometimes is just better to start over with a stock tune. Don't know why, but the tune file somehow gets corrupted and doesn't work as expected.
A fresh tune file fixes many issues.
Old 07-24-2012, 12:57 AM
SSpdDmon's Avatar
Sounds like the TC is locking/unlocking... You may need to adjust the light throttle lockup to avoid having the converter lock when engine RPMs are lower than drivetrain revolutions at that speed.
See http://forum.efilive.com/showthread....4-shift-points
Old 07-26-2012, 11:49 AM
Thanks guys
I have set the PWM table to 100%, and it didn't seem to help (thought it would)
It actaully acts a lot like the traction control, since that would pull timing to reduce power and tire spin
I have palyed with the part throttle lock up, and where ever I put it, it moves the problem there. I set it to 60mph, to see if it would move it, and since my wife drives faster than that, it is still giving her problems. She says it is "skipping". I say both problems are driving me nuts
Old 07-26-2012, 04:41 PM
GA95DCMSS's Avatar
Originally Posted by BOTTLE ROCKET
Thanks guys
I know this seems REALLY elementary, but have you checked the trans fluid level? I had this happen after installing a built trans, luckily it started on the way to the parts store.
And about the bogging, when you go WOT from a dead stop, does it bog for a few seconds and then somehow find its rythm and take off? If so, check the upper MAP regions of the VE table in the Lower RPM columns, they may need to be adjusted after the head install. I had the exact same symptom I described, and that's what fixed it.
Old 08-11-2012, 09:16 AM
Well:in regards to the bucking, Ive checked the fluid level, have the TCC duty cycle at 100% raised the lock up to 62mph, and that's when it starts , so it must be the convertor locking and unlocking
What am I missing??
Old 08-11-2012, 10:00 AM
BLK02WS6's Avatar
Post the tune...
Old 08-11-2012, 11:10 AM
salemetro's Avatar
^^^ +1 .......a log of the Trans would also help.
Old 08-11-2012, 11:37 AM
This is the last one I have
I moved the part throttle lock ups lower, but it still does it at any speed AFTER lock up
If I shift to 3rd, where I have no lock up until a high speed, it never does it
File Type: hpt
Old 08-18-2012, 07:15 AM
Anyone see anything that might cause the unlocking issue?
Old 08-18-2012, 04:45 PM
Temporarily disable misfire detection to see if it maks a difference
Old 08-24-2012, 07:47 PM
Do I just change the enable temps?
Thanks
Old 08-24-2012, 07:52 PM
BLK02WS6's Avatar
Its not misfires, they are already disabled...
Old 08-24-2012, 07:57 PM
joecar's Avatar
From what you said so far, it sounds like the TCC is not able to hold...
since TCC apply pressure is regulated from line pressure, you should physically check that your line pressure is not falling down.
Old 08-26-2012, 03:10 PM
That is what it seems like; which is why I wondered if it is a bad TC
How do I read the pressure? Are you saying I have to install a mecanical guage somehow, or is there somthing in HPTuner that will read it?
Old 08-26-2012, 06:14 PM
There is no pressure sensor to log transmission pressure.
You need to hook a mechanical pressure gauge, it is 1/8 NPT, use this chart to command the Motor current and see if the gauge matches
Start with the highest mA value of the table and go down. Less mA gives more PSI
Old 08-26-2012, 10:56 PM
joecar's Avatar
Like Monte said, do the static test, but also look at the pressure while you drive.
Old 08-27-2012, 04:08 PM
Yes, that's right
Get a long flex tubing and hook the gauge in front of you and drive the car
I tape it to the windshield so I can watch it the moment the problem happens
Quick Reply: TC or tune
