Efi live help
Old 07-28-2012, 04:44 PM
Mustang Hat'r 2's Avatar
Default Efi live help
I finally got my V2 scanner to work, I logged a data file and I pulled the tune out of the ECU. Its a 98 camaro. How the hell do I look at the files? I can save them, I have the scanner hooked to my PC but I cant see ****. Thing is making me nutts.
Old 07-28-2012, 06:51 PM
BLK02WS6's Avatar
Read the manual - under the help menu, click help contents...
Old 07-29-2012, 05:04 PM
I must be retarded or something, I still cant get figure this out. I have 5 different icon for this thing when ever I try to open a file I have the chessy one that come with the software or it wants me to connect to the car. I cant look at the file that are on the V2 scanner.
Old 07-30-2012, 09:53 AM
kenp's Avatar
Click on the EFILive Tune Tool icon. Click on File, then open. Select the tune file you want to view. Click on Engine Calibration. You should be able to see all of the calibrations in the tune file.
If you want to look at a log, you have to use the Scan Tool icon. Same thing. Open a file and then you can play it, look at the maps, and follow the values of the PID's.
Old 07-30-2012, 12:12 PM
I'm doing that stuff but what I'm missing is getting the file from my V2 scan tool to that location. I've been playing with it I have the tune file I can look at now but the data log looks like its a notebook file and not the correct format. Maybe it didnt save correctly when I logged it. I was doing the log then I just shut the car off and unplugged it. Is there another step to get the log file saved in the V2?
Thanks you for the help guys.
Old 07-30-2012, 08:12 PM
Got it figured out, guys on EFILIVE forum got me straightened out.
Thanks
jay
Old 07-30-2012, 08:26 PM
joecar's Avatar
You got the log file and the tune file moved from your V2 to your PC...?
Now, open them using the V7 scantool/tunetool, you should see your tunetool highlight the cell that the scantool cursor is on... (for some pids you have to first set them to the same units as is shown in the tunetool, e.g. set MAP to Metric in the scantool, then in the tunetool on the VE table axis it follows the scantool cursor)
[ you also have to do this: in the tunetool, go Edit->Properties->Scanner and checkmark both items under Pid Data Links ]
Old 07-30-2012, 09:36 PM
Dam bro your all over the place, you got me taken care of on the EFILIVE forum.
Thank you for all the help
Old 07-31-2012, 01:19 PM
joecar's Avatar
Quick Reply: Efi live help
