24x Reluctor Wheel 58x PCM Programming Fix?
Old 01-02-2013, 08:58 PM
jad568's Avatar
Default 24x Reluctor Wheel 58x PCM Programming Fix?
I'm looking to install a nicely built LS2 into my 07 Z06. The issue is the LS2 has a 24x reluctor wheel and my PCM is obviously looking for a 58x wheel signal. I was planning on using the LINGENFELTER converter box but it now sounds like they are on hold pending more testing!
Sooooo, I don't really want to pull the crank to get a 58x wheel pressed in so I'm wondering if anyone has had any luck at getting the the PCM programming to make the change there? I'm assuming this may not be possible or Lingenfelter wouldn't have made the module.
I'm still curious to see if anyone has found a way to get into that programming area or has found another way around this issue.
Thanks,
-John
Old 01-02-2013, 11:16 PM
James@ShorTuning's Avatar
Not capable of changing reluctor wheel specs in these ECMs.
You could however pin your crankshaft and install a 58x reluctor on the front of the balancer with a crank sensor if you arent wanting to pull the crank. I personally like using the correct reluctor vs using a conversion box... just works better.
Old 01-03-2013, 11:31 AM
jad568's Avatar
Thanks for the heads up.
Old 01-04-2013, 12:35 PM
soundengineer's Avatar
Lingenfelter makes a box you can install that does 24x to 58x or 58x to 24x
I have 2 friends using it, it works well
Old 01-10-2013, 11:48 AM
wait4me's Avatar
If you have EFIlive, send me the tune and I will change the signals for you. It will work just fine without changing the hardware.
Old 01-10-2013, 05:48 PM
Curious about this... not seen it done via software to date or did you go into the code and alter it that way?
Old 01-10-2013, 08:57 PM
joecar's Avatar
He would have figured out where that table/parameter is located in that OS (and defined a cax entry for it).
Old 01-10-2013, 09:40 PM
That's what I figured however this swap isn't a simple change with the major differences in the reluctor wheels. Either way it wouldn't benefit me anyhow because thats one of the drawbacks to HPTuners software is the inability to access the raw code of the bin files.
Old 01-14-2013, 10:20 AM
69 Ghost's Avatar
Any updates on this? I would like to know if this is a future capability of EFI or if it is just a Jessie Special. I am interested in any details you want to provide.
Old 01-14-2013, 10:22 AM
wait4me's Avatar
It is something only I do, It is a mix of a bit of little things to make it all work. It is what I was running on my 1000hp Ctsv as well, so I know it works on any e67 and e38 ecm.
I don't charge anyone to set up the tune, it just isn't something im going to put in the software for everyone.. Well at least not yet.
Old 02-12-2013, 04:54 PM
Mike454SS's Avatar
Jesse, after you make this change, is it still possible to apply a custom OS for things like lower temp cooling fan control and switchable N20 settings? Obviously you don't wind up with any sort of tuner lock on the file that would prevent the car owner from tuning the car himself in the future right? Does it affect things that are timer related to crank pulses or will that type of thing still work normally? I think for the most part on the Gen 4 computers, those type of things reference either crank degrees or a single "reference pulse" which I assume to be cylinder #1 TDC.
Old 02-12-2013, 06:55 PM
10 Second Truck Club
67SS509's Avatar
Can you make a LS1B style PCM operate with a 58 reluctor crank?
Old 02-13-2013, 09:44 AM
wait4me's Avatar
No. It does not have the function base set code for it to work. I can however make it 1x.
Old 02-13-2013, 06:50 PM
Mike454SS's Avatar
Can you reply to my question?
Old 02-14-2013, 04:23 PM
Glad to have this option now! As I now also have EFILive! Thanks for the support to the sport!
Old 02-15-2013, 11:14 AM
wait4me's Avatar
Feel free to contact me if you need anything James.
Old 12-23-2013, 06:26 PM
chopperloco's Avatar
....spoke with Lingenfelter today,the 24t reluctor in a 58t vehicle never went into production...
Old 04-02-2018, 06:50 PM
Ddwill8701's Avatar
Default Change signal 58x to 24
Hey I have efi live. Could you change my reluctor wheel signal to 24?
Old 04-03-2018, 10:15 AM
pantera_efi's Avatar
Default Crank Senos Color
Hi ALL, the 24xe = BLACK CS AND the 58x = GRAY CS.
I have the Gray in stock ?
Lance
Old 04-05-2018, 05:38 PM
LSX Power Tuning's Avatar
Hes no longer a sponsor on here. Google his screen name and you can find his contact info.
Quick Reply: 24x Reluctor Wheel 58x PCM Programming Fix?
