ecm swapping?
ecm swapping?
question for you guys my friend and i both have 98 cars mine is a 98 trans am a4 his is or was a 98 ss we had the same mods but he had his tuned by frost before he wrecked it. mine is still untuned. is it possible to swap out the ecu so i can have the tune in my car. like i said we have the same mods. longtubes. 3.73 gears underdrive pulley etc.
If both cars are automatic yes.
Vats will be a problem, if you are asking this I assume you don't have tuning software. If that's correct then vats will be a problem. I don't know if you can do a vats relearn using the 30 min procedure with a 98
It's worth a try
It's worth a try
