First time w/ EFILive, getting knock retard?
Old 02-06-2013, 03:05 PM
Ferocity02's Avatar
Default First time w/ EFILive, getting knock retard?
Bought EFILive V1 from Blackbear and did some scanning on the way home from work just to play and get the hang of things. I noticed that in 6th at low RPM (~1700) and higher TP (40-60%) I could set off some KR. I couldn't get it to do it consistently. I got up to 8 deg of KR.
Tune is a mail order from Calspeed for the T56 swap in my Silverado 5.3L, stock heads and LS1 cam. Only thing that has be changed since is the addition of a 212/212 114LSA cam and unported 799 heads. No tune has been done since the heads and cam.
Should I be worried? Could it be false knock? I tried to listen but it's hard to hear anything other the sound of the exhaust and other misc noises. I did once here a "tink" sound and got some KR immediately.
Here's a snap shot of the log. I was on the highway varying TP to get some KR.
First time w/ EFILive, getting knock retard?-s6yjlp7.jpg
Old 02-06-2013, 03:50 PM
LS1Tech Sponsor
Slowhawk's Avatar
Thats really hard to read. Could be anything. post a log file.
Old 02-06-2013, 03:56 PM
Ferocity02's Avatar
Log is attached. Not sure if it has all of the data you might be interested in. I only switched on a handful of PIDs. Still new to this.
File Type: efi
Old 02-06-2013, 08:28 PM
joecar's Avatar
O2 sensors look like they are old worn out.
Old 02-06-2013, 08:35 PM
Ferocity02's Avatar
Why do you think that? They are about 1 year old with 10k on them, came new from Delphi.
Old 02-06-2013, 09:26 PM
joecar's Avatar
They're not ranging/swinging sufficiently, they should reach above 700mV (even above 800mV), and they should swing more consistently...
the trims that are added should have them swinging/ranging correctly and consistently, but they're not.
Old 02-06-2013, 09:28 PM
joecar's Avatar
You're getting knock due to being lean, especially since PE is not enabling sufficiently early (look at AFR waveform).
Old 02-06-2013, 10:21 PM
Ferocity02's Avatar
Yes, I noticed the AFR doesn't drop until around 90% TP.
The bank 1 average 491 mV and bank 2 was 514 mV, excluding the data from warm up. Is this difference okay?
Thanks for the help!
Old 02-07-2013, 08:08 AM
LS1Tech Sponsor
Slowhawk's Avatar
Yup, tune is off a good bit.
Old 02-07-2013, 08:54 AM
wait4me's Avatar
Tune needs some major tweaks. Email me at jessebubb@yahoo dot com and I can make the changes I think it needs. send the tune file, and send me that log all in one email explaining what is wrong.
Quick Reply: First time w/ EFILive, getting knock retard?
