Downshift for passing tune
Old 10-22-2013, 07:02 PM
Monte4ever's Avatar
Default Downshift for passing tune
I have a 4l80e that I want to tune so that it will downshift in a passing situation. Right now I have to almost floor it to get it to downshift from fourth to third and OD to third. Should I change the TPS to WOT settings?
Old 10-22-2013, 09:31 PM
2xLS1's Avatar
No...
Old 10-22-2013, 10:14 PM
Monte4ever's Avatar
Originally Posted by 2xLS1
No...
Lol.....thanx. Would you care to share a little more info or guidance?
Old 10-22-2013, 11:33 PM
2xLS1's Avatar
Sure just as soon as you share a little more info on the vehicle. And maybe some info on what you are using to tune with.
Old 10-23-2013, 12:30 AM
Monte4ever's Avatar
Ok. Its an LQ9 iron block 403 with 9.5 comp, F1A Procharger, Edelbrock intake, 83bl injectors, FTI 3600 stall and 4l80e. My last WOT log showed approx 13psi boost using Hptuners Pro software.
Old 10-23-2013, 12:37 AM
2xLS1's Avatar
Geez. What computer and vehicle cal is in it. You know. Info that might be relevant to the tables in the calibration.
Old 10-23-2013, 01:12 AM
Monte4ever's Avatar
Oh - ok lol........Its a 411 PCM with a 2002 Camaro OS. I'm at work so off hand I think the last three numbers of the OS is 156. It has the 4l80e segment swap.
Old 10-23-2013, 04:43 AM
Mister Peebody's Avatar
Curious as to why you want it to downshift. I tuned my A4 to only downshift from 4th to 3rd, never 3rd to 2nd, or 2nd to 1st. I did this because even with drag radials 1st and 2nd are useless over 35% TPS. You should be making near or above 700rwhp with your combo so your power band should be such that you don't need the gear especially with the 3600 stall. Any way, if you are using HPTuners then:
Trans - Part Throttle Normal - "Shift Speed vs %TPS vs Shift" is the table that you want.
Old 10-23-2013, 08:50 AM
2xLS1's Avatar
In the highlighted cells, once you are above that MPH it won't downshift. Put higher numbers in those cells to make it downshift with less throttle input. One way you can do it is to decide on a spread between the upshift mph and the downshift mph for each tps setting. For example on the 2-3 ans 3-2 try something like 15 mph. For every cell where the difference between the two numbers is more than 15 mph, increase the number in that downshift cell to where the difference is 15. Try different spreads until it is downshifting how you want it to.
Old 10-24-2013, 04:23 PM
Monte4ever's Avatar
Thanks for the reply. I am looking for it to downshift from 4th to 3rd for passing. I cruise around in 4th gear on the street most of the time.
Old 10-24-2013, 04:25 PM
Monte4ever's Avatar
2xLS1 thanx for the info. I will give this a try.
Quick Reply: Downshift for passing tune
