MAF sensor...keep or remove screen? Debate.
Old 10-25-2013, 09:20 PM
CGT77's Avatar
Default MAF sensor...keep or remove screen? Debate.
OK, on my '02 Camaro LS1, I had a bigger (screenless) SLP MAF sensor, but after reading all the "bad" things about them, I'm removing it and putting the stock one back on. Also had a tuner tell me to just remove it (the SLP MAF). Haha! I have a SLP lid and smooth flow bellow, so, would removing the screen help or hurt? Everything I've read on it is about 50/50.
Old 10-26-2013, 02:27 AM
8 Second Truck Club
Blown06's Avatar
I agree with your tuner. Just skip the maf.
Old 10-26-2013, 03:12 AM
Fast86z's Avatar
I would get rid of it too.
Old 10-26-2013, 09:58 AM
MMWS6's Avatar
Thankfully the SLP did come with a GM sensor in it but without the honeycomb its no good. If you run a MAF, get a honeycomb in there. I bet you could just add the honeycomb to the SLP one and it will fix your issue with a little tuning
Search Paxon I think it was over on HP and you can get cell count and length custom to your preference
Old 10-26-2013, 10:07 AM
CGT77's Avatar
Sorry for the confusion. I'm removing the SLP MAF sensor and reinstalling the stock MAF sensor with the SLP lid and smooth flow bellow. My question is, should I remove the screen in the stock MAF sensor before installing?
MMWS6's Avatar
No Honeycomb:
With:
Should sum it up for you there
Old 10-26-2013, 10:19 AM
CGT77's Avatar
Originally Posted by MMWS6
No Honeycomb:
With:
Wow. That's interesting.
Old 10-26-2013, 12:19 PM
LS1Tech Sponsor
06MonteSS's Avatar
LS1Tech 10 Year
you want to keep the screen IN... do not remove the screen...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 10-27-2013, 06:03 AM
danieloneil01's Avatar
So you're setup in the pics is from a PC fan with and without the screen?
Old 10-30-2013, 11:26 AM
CGT77's Avatar
So I decided to leave the screen in. Was installing my stock MAF sensor into the end of my SLP lid and crack! The lid split at the seam. I heated it up, lubed it and everything. Still broke. Fantastic.
Old 11-01-2013, 06:30 PM
MMWS6's Avatar
Yup, but the principal is there. I wish people would call them what they really are then all this debate would cease. They are "Airflow Straighteners". They are not a screen, they are not meant to protect anything as calling them a screen would imply.* Although they obviously will protect your engine from large debris getting into your engine but really, that is what the air filter is for. People call them a 'honeycomb" because of the shape. OK, I get that, but it is still an Air Straightener that resembles a Honeycomb when viewed face on.
Old 11-01-2013, 07:17 PM
9-Second Club
Ed Wright's Avatar
^^^ Exactly!
Old 11-02-2013, 09:06 PM
maf_diver's Avatar
The old 75mm mafs give nice stable readings with or without the screen as long as you don't have a bend right in front of them. You will need to fatten the curve a few %, but it's easy to do if you have a tuning suite and a wideband.
If you're not willing to recalibrate it or pay someone else to do it then leave the screen alone. If you can do it yourself it's free HP. Reduces intake restriction by about 1kPa.
A descreened maf is still more stable than an SD tune, and only a minor restriction on a stockish motor.
Quick Reply: MAF sensor...keep or remove screen? Debate.
