Tuning with dan Maslic's book
I’m trying to tune my first engine build using Dan Maslics “Master EFI Tuner” book with HP Tuners (basic). I’m using Case Study 3 and can‘t get past the first step. I’ve set my ECM up by his criteria and am not having any luck tuning the Idle MAF AFR calibration. My target AFR is 12.5 and my actual reading is 14.5. I keep adjusting my “MAF Airflow vs. Output Frequency” (from 3,000hz and lower) to richen the mixture to equal 12.5. Each time I do, the STFT (reads -45 after 2 ) keep pulling more and more fuel out but my wideband always reads an AFR of 14.5. Does any know why this is?
Tune
That's what it seemed like to me to. The book's setting is supposed to be putting the ECM in open loop. Is it not? Should I just disconnect the MAF? The AFR was set that way because that is what the book set the target AFR at.
Its just a safe way to tune, its set to 1.17 in open look eq ratio. When you crank it up the chances of it going lean are rare. You leave your stoich table alone. When you change it back to normal operation your eq ratio goes back to 1.00 and it all falls in to place. I tune this way and its great. I've read a few of the tuning books and the mast book is my favorite.
Maybe you should pm the OP and tell him how its done since all you seem to be doing is saying I am wrong and not offering "the right way to do it" Sorry OP for wasting posts, I will not be replying to the thread again.
Did you post your mods list?
1st your going to need to put it in open loop (OL).
Then command 1.0 (EQ Ratio) or 14.7 a/f ratio on your EQ ratio table
If you dont put it in OL the o2 sensors are going to use fuel trims to try to correct the fuel to 1.0 EQ ratio or 14.7 a/f. Then you can start the process of tuning your VE table and MAF. Thats not every single step, but will get you going. I'll look through the tune some more tomorrow, just saw those things right away.
Mods
Sorry, here they are.
LS1 / 3.908” bore
Mahle pistons / 4 CC valve relief
6.125” rods
PRC Stage 2.5 5.3L CNC Ported Heads 10.72 cr.
Melling high pressure pump
Crane cam 1449591 / .551” lift, 286 duration (224 @.050“)
Comp cams 918 valve springs
Comp cams pushrods
LS6 valley cover
LS6 intake
LS2 timing chain
Injectors / 0280155811 (24508208), 42# @ 58 PSI.
MAF / 89873788221
1 ¾” long tube headers
Ported 75 mm. MAF ends and throttle body
LS1 / 3.908” bore
6.125” rods
Comp cams pushrods
LS6 valley cover
LS6 intake
LS2 timing chain
MAF / 89873788221
in engine.fuel,open&closed loop,you have short term trims enabled in open loop.so your o2 sensors will use short term trims to correct a/f ratio to stoich.you need to disable if you want to see what the maf is doing. but,you better reset maf values to original to start with or it most likely wont run due to the changes you made.
