Commanded AFR question
History: New engine, PRC heads, and procharger installed. Tuner was never able to find/fix a random misfire >4800 RPM. Tried new coil packs, new ECM, plugs, wires, checked springs... I eventually had to retrieve the car and I'm trying to diagnose the problem.
Issue: I noticed via my Aeroforce gauge that the misfire exactly matches a drop in the commanded AFR on my gauge. Commanded AFR sits at 14.6 at all RPM's up until ~4800RPM, at which point it quickly drops to ~9.0. At this point the car begins to misfire, loses power, etc.
The catch: The run logs I saw while he was tuning were as flat as could be... AFR never wavered. The fact that the measured AFR's didn't waver would make me think it doesn't really matter what the commanded AFR is... the actual AFR measured at the tail pipe was perfect. Have I potentially ID'd a problem, or is that illogical?
He tried MAF tuning, SD tuning, re-flashed back to stock and started from scratch... the car always started misfiring at about the same place. It misfires at WOT, and also if I very slowly creep up to those upper RPM's and just hold it there... it makes no difference.
I will ask the tuner if he will e-mail me the tune and a run file. They changed the plugs and wires, so I will have to check on the model and gap. I'm running premium 93 octane, on siemens 60lb injectors.
I forgot to mention the misfire is present with meth turned on or off. With the misfire also happening when not at WOT, just when I'm slowly easing into those RPM's, does that rule out that it's caused by spark blow-out?
OK, so out of desperation we unplugged every electrical terminal under the hood and re-snapped them together to make sure everything was snapped down good, loosened and re-tightened every hot and ground wire we could find... and it seems to be running fine.
