g\cyl falling near redline?
I'm finding that my g\cyl are falling near redline, I would think this is basically stating my MAF is increasing at a slower rate then RPM and might indicate that I'm exceeding the capabilities of the stock airbox?
Seem likely, or have I misunderstood something?
Moderator
No, this is your intake restriction and exhaust backpressure
limiting airflow, hence per-stroke air mass. Torque follows
air mass. Horsepower follows air mass flow. You should see
g/cyl start to fall away about the same place and rate as
your torque curve, if you have a dyno chart.
