Alcohol % PID
LS1Tech Sponsor
there are no flex-fuel tables in that old pcm... in a newer flex fuel vehicle with newer ecm's, there are separate tables specifically for e85.. separate timing tables, afr tables, etc... which are not available in that old pcm on that old truck.. and no, there would be no alcohol % pid's in that either, since it was never made for flexfuel/e85, so it never had any sensors for it.. so no parameter to log for it...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
There is only one for that OS. In HP Tuners the alcohol PID is located under Fuel System > Alcohol Percent. There isn't a fuel temperature PID available for that vehicle that I'm aware of.
If you can't see it, you may have to use the "Clear Last Used Vehicle" button and reconnect.
