tunercat tuning for LT1 4L60E to 4L80E swap
Hi,
hoping to get some information before I dive into this. I have a 95 LT1 with an S trim supercharger, advertised as 500+HP and PCM is tuned for the blower, cam, head work, etc..and the engine came with a stock 4L60E that was swapped into the car, I assume the last trans gave up.
I want to put this engine into an older car and swap to the 4L80E just to give the trans a chance to live. I have found the pinouts for the two transmissions, looks like one wire has to be moved, and the logic has to be reversed for one shift solenoid. I have tunercats and have read that I can do the logic swap with tunercats instead of hard wiring the change. Does anyone know exactly where and what I have to change in tunercats? Also should I make any changes to the transmission tables with the 4L80E? Any help would be appreciated, I dont even want to try using the 4L60E.
Found all the information online, pinout change, how to reverse the logic on the shift B solenoid with the relay or with tunercats, now just have to try it out. Only thing I have not found yet is if there needs to be any wiring done with the 2nd VSS sensor, I will post in the drivetrain forum. I am suprised I did not get any responses here yet, figured it would be pretty common knowledge with the amount of 4L80E swaps out there.
Does anyone know what table in tunercats shows the solenoid logic so I can reverse the logic for the shift B solenoid? Rather not use the relay to reverse it if I can do it in the software. Also are there any fault codes or changes to the 4L60E tables that will make the 4L80E shift better using that program? Wasnt sure if the first gear difference was a big deal or not, also would like firm shifts if possible.
I know this is an old thread but did you ever get this to work, if so can you give me details please, on exactly how to do this to get the 4L80E to work with the 1995 LT1 ECM.
